  #1
Old September 18th, 2008, 02:51 PM
Redmen Redmen is offline
Unhappy 1997 25HP 3cyl. Evinrude Stalls/Won't Start
I have a 1997 25HP 3cyl Evinrude electric start outboard. I have unhooked the oil injection system and am mixing oil in the tank. Last year the outboard began stalling at trolling speed. It then began to run at half speed even when the throttle was running wide open. This would happen intermittently. Then, there were times that I would start the engine cold, drive 2 miles to my fishing spot. Fish for 1 hour and the motor would not start. If I waited 20 - 30 minutes it would eventually start and would run at half speed and cut out on the way home. I thought it was a gas problem so I changed the gas filter and cleaned the carburetors. Still the same problem persisted. I took it to the Marina and they claimed that it needed a water pump. This was replaced but still it did the same thing. What else could this be? Does this sound like a power pack problem? How can I check this? Does anyone else have similar issues? Thanks.
  #2
Old September 18th, 2008, 02:56 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 1997 25HP 3cyl. Evinrude Stalls/Won't Start
have you checked you spark when it is messing up, the only way to tell. could be power pack, coil failing, crud back in the carbs. vent not open on the fuel tank. hose connected backwards, arrow on bulb, points toward motor.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old September 18th, 2008, 04:47 PM
I've cleaned the carburetor out a few times. The vent is open on the tank and the hose is connected to the outboard correctly. I've changed the gas filter. What electrical things could it be? The power pack, spark plug wires, coil? I guess I need to get a spark plug tester and test each cylinder's spark when it happens. Is this how you would approach the problem?
  #4
Old September 18th, 2008, 06:15 PM
yes, exactly, and immediately.
__________________
FLORIDA GATORS
TEBOW Country
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1975 3cyl 65hp stalls after brief high speed Helly Mercury & Mariner Outboards 3 August 4th, 2008 09:20 PM
'94 60hp Mercury 3cyl. stalls after 1/4 mile... Trackerjack Mercury & Mariner Outboards 4 June 29th, 2008 01:46 AM
1996-1997 25hp Evinrude thrust probs.. d4d4pk3rs Johnson & Evinrude Outboards 2 January 6th, 2008 09:20 PM
1997 25hp Evinrude Fuel Mixture dynomike Johnson & Evinrude Outboards 1 April 27th, 2006 09:31 AM
1997 150 evinrude won't start seabassin Johnson & Evinrude Outboards 13 October 5th, 2003 04:40 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
