hi ,
i just bought a 15 ft mako with a 1988 70 hp johnson the vro unit has been disabled and iam running 50 :1. took the boat out for the first time it ran great. the second time i took it out the engine cut back on its own to idle when i was running wot. would not run faster than an idle all the way home. i got new gas and conditioner changed plugs and put a new fuel filter on it. the engine did the same thing again. i hooked up the muffs at home and started the engine ,i gave each cylinder a tiny shot of carb cleaner. i know im not supposed to do that but i did anyway. starting from the top carb it bogged so did the second but the third when shot rpms increased . i shut it down and got some seafoam to put in the gas to clean the carbs through the jets. am i wasting my time or do you think the bottom cylinder is dead.and what should i do, iam not a mechanic. any help would be appreciated
thanks
douglasb
thanks
douglasb
