rs2k
- Aug 2, 2008
- 486
I had a bit of trouble when I tried to flush the engine after three hours of boating today. I didn't see any water coming out of the hot water holes of the engine but I thought this was just because the thermostat wasn't open. The overheat horn sounded after about a minute and I shut it down. It's odd that I was able to run the engine for three hours without trouble. When I tried pressing the engine flusher tighter onto the engine I heard a little water movement in the low end and finally noticed some warm water coming out of the hot water holes, but not like it usually does.
Could the thermostat have gone bad?
Could the impeller have broken?
Could I have something blocking the coolant passages?
Because the overheat horn sounded could I have damaged the engine by running it hot?
