Bought a used ski boat and motor in 2000 ( motor 1980 140hp). Everything ran great til 2004,at which time the engine would not charge and the tach would no longer work. Asking for advice from this site, I replaced the rectifier and my problems were solved. In 2006 an intermitent spark problem occured, and following advice from this site,I replaced the power packs, coils, and on somebody's advice checked the stator and timer base assemblies,which I also replaced, (had that gooey shellac like substance dripping down onto everything). Now this summer the tach won't work, checked the rectifier found it faulty,replaced it, now everything is working fine. Now my problem is do you think that this is the beginning of me having to replace all the parts that I previously mentioned again after only 2 summers worth of use.
The boat is used maybe 20 hrs. a summer tops.( no cottage so I have to trailor it everwhere)
Bailey
Bailey
