  #1
Old September 15th, 2008, 10:38 AM
PISTONESAL PISTONESAL is offline
Default Alarm in center console
Hello,
My dad has a 2001 Proline with a 125 mercury outboard. Every so often this loud squealing alarm comes on. It has done it intermittently. The last outing it started and never stopped. When we got home after an hour of pulling the boat out it would still do it when the key was turned to on without turning the engine over. I checked the temperature guage and it was fine. The motor was filled with oil. Anybody have any ideas what the alarm is sensing? I appreciate any help.
Thanks
Sal
  #2
Old September 15th, 2008, 01:07 PM
Laddies Laddies is offline
Default Re: Alarm in center console
Start by disconnecting the sender wires if that stops it you have a bad sender, if it don't disconnect the wire that rounds to the horn at the engine. If that stops the horn it's the module (some newer engines don't have modules you will have to check yours) if that don't stop the horn you have a wire shorted.
  #3
Old September 15th, 2008, 04:14 PM
Which are the sender wires? The alarm is coming from the console area not the engine. Please help.
Thanks
I appreciate it
Sal
  #4
Old September 15th, 2008, 05:05 PM
The signal that sounds the horn come from the engine there are 2 senders one on the head for temp. with a tan wire going to the module and one on the bottom of the oil tank for low oil with 2 blue going to the module, the module when sends it's signal to the horn on a purple wire.
  #5
Old September 15th, 2008, 10:08 PM
CharlieB CharlieB is offline
Is this one continious beeeeeeeep
or a continuing rapid beep beep beep?
Solid tone is the temp alarm, tan wires
rapid toons are the oil alarm, blue wires, Unplug one or both wires to the switch under the stbd side of the oil tank. If this stops the beeping, order a new tank, the magnet came loose from the float.
  #6
Old September 16th, 2008, 11:17 AM
It is a long continous beeeeeeepppp. Very annoying..
  #7
Old September 30th, 2008, 07:05 PM
I disconnected the oil tank wires and the lon non stop beep went away. I assume it is the switch in the tank but Mercury sells the tank and switch seperately. So, does that mean all I need to replace is the switch and use my current oil tank? Please advise.
Thanks
  #8
Old September 30th, 2008, 07:20 PM
achris's Avatar
achris achris is offline
Send a message via Skype™ to achris
As you have been told in your other thread for exactly the same problem , it's not the switch, it's the float with the magnet glued on the bottom (not any more). This is a VERY common fault with these oil tanks... Merc makes a lot of money out of selling them...
Chris...............
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
  #9
Old October 1st, 2008, 09:39 AM
Sorry. I just want to order the correct part and do the job once. Do I replace the tank and use the same switch or both need replaced at the same time?
  #10
Old October 1st, 2008, 09:43 AM
Never mind. I got the response I needed from the other post. Sorry. I kept reading the wrong threads..
  #11
Old October 1st, 2008, 03:27 PM
achris's Avatar
Quote:
Originally Posted by PISTONESAL View Post
...... I kept reading the wrong threads..
Me too....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Center console to standard console Bozol Boat Restoration and Building 2 August 26th, 2008 12:09 AM
Center console v dual console Kachadurian Boat Topics and Questions (not engine topics) 14 December 22nd, 2007 08:13 PM
New Boat: Center Console , Walkaround, or Dual Console PAkev Boat Topics and Questions (not engine topics) 17 April 2nd, 2006 08:14 AM
center console gbf03 Boat Restoration and Building 6 February 28th, 2004 05:23 AM
Center Console Scott-14 Freshwater Fishing 1 September 30th, 2003 03:48 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
