water pump/impeller 86hp evinrude 85895C 1978
i have an 85 hp evinrude 85895C 1978 . its actually running fine, but i did notice it seems to be running a bit hotter than i remember when i first got it, and seems like there is less water coming from the weep hole . So i have decided to tear into it and replace the water pump/impeller. there seems to be an endless variety of parts and kits to do this.
Can anyone suggest a part number for a kit to do this ? also, does the kit come with instructions? just so you know, i would rate myself high as an auto mechanic, but still green as a boat motor mechanic .
Also, is there any other parts that i should replace while i have it torn down somewhat? i have read other post that mention thermostats,but i don't see any listed on the parts list from BRP.
i have found this from brp , is this all i would need ?
83 More Details 0389158 WATER PUMP REPAIR KIT
is the chrome version better?
84 More Details 0389165 CHROME PUMP KIT
thanks! allen
