  #1
Old September 13th, 2008, 08:06 PM
kenlynn kenlynn is offline
Default mercury 850 wiring diagram
I bought a 850 mercury s/n3741831 {don't know the year either } with distributer . It will not fire . the brown wire on the ignition side of brain box runs back to key switch but is not hook to nothing. The white wire same side is hooked to red, nothing were the white wire is supposed to be. Does someone happen to have a wiring digram for one and could someone tell me what year it is
  #2
Old September 13th, 2008, 11:36 PM
emckelvy emckelvy is online now
Default Re: mercury 850 wiring diagram
Looks like your motor is a 1973. The brown wire is the tach wire and for use with old Merc tachs the wire was connected to the switchbox. For newer tachs which use a signal from the alternator, the wire would be connected to one of the two yellow stator wires hooked to the rectifier.
The white wire on the same side of the switchbox as the red wire should be connected to the white terminal on the switchbox. The white wire provides switched +12V to the switchbox and may be the reason you have no spark. Otherwise I bet the trigger assy is shot.
Here's a link to wiring diag for your motor:
http://www.maxrules.com/oldmercs/Wiring/1966ona/30.gif
And here's some info on how to troubleshoot the Merc CDI distributor-type system:
MERCURY BATTERY-POWERED CDI TEST FOR DISTRIBUTOR MODELS
This test is for the 332-2986 switchbox used from 1967-1978 on all the inlines.
This test assumes your coil is good (problems with CDI coils are rare).
DISCONNECT BATTERY
1. Turn off ignition;
2. Disconnect all 3 distributor wires on the Port side of the switchbox (and the “mercury switch” if present);
3. Remove the HV lead from the ign coil to the center of the dist. cap (remember it unplugs from the coil and unscrews from the cap);
4. Reconnect the HV lead to the COIL only;
5. Position the free end of the HV lead approx. 3/8" from ground (block, shrouds etc), and find a way to hold it there;
6. Jumper the brown and white terminals on the dist. side of the switchbox to each other.
RECONNECT BATTERY
7. Check that you have +12V at the red terminal (even with the ign off);
8. Turn on ignition and verify +12V at the white terminal (same side as the red terminal);
9. Ground the black terminal on the distributor side of the switchbox - this should cause a spark each time you touch ground.
If you get spark with the distributor bypassed, and it won't fire with the distributor connected, the trigger is bad and the entire distributor housing assy must be replaced.
If you get no spark using the test, the switchbox is probably bad. In that case, be sure to check for correct power on the switchbox, check all connections, and check the coil's resistance to make sure it's OK.
HTH............ed
  #3
Old September 14th, 2008, 05:11 PM
They had the white wire back feeding key switch. Moved white back to igition box did not have no voltage on white wire. Started looking red was broke that feeds key switch fixed it. I now have fire at all plugs, but it will not run pops and gets real stuborn turning over. What is the firing order maybe they have plug wires on distributer wrong You know what i mean . Where woul i get firing order at and how they hook to cap. Thanks Ken.
  #4
Old September 14th, 2008, 06:57 PM
There should be numbers cast into the cap on the end where the spark plug wires go in. Note: #1 cyl at top, #4 at bottom.
BTW the wires screw into the cap so don't try to pull them out as it's possible to pull the wires completely out of the crimped threaded terminals. This includes the coil wire; but at the coil end it just pulls out (with quite a stout pull, usually).
You may also want to pull the clamp off the cap and check inside for debris/trash. Carb cleaner in the spray can works real well for flushing junk/gunk out of the inside of the cap. Just don't spray on the trigger or other parts in the dist, just the cap itself. Also check the center carbon contact, it's spring-loaded and should be free to move in its hole. If not, pull it out and clean. The bottom of the spring is a bit bigger than the hole it goes in, you just twist it into the hole and it'll conform to the smaller diameter.
If you have no luck with the cap, you might also want to check dist. belt alignment, who knows what else they've haywired!
Set the flywheel at TDC per the timing marks, and remove the top guard off the dist. pulley, you'll see an arrow cast-into one of the ribs of the pulley.
When the dist belt is properly aligned, this arrow is supposed to point to the timing marks (typically punch marks or a scribed line) on the flywheel and on thru to the centerline of the crankshaft. It should either be 'dead on', or the arrow should be pointing a bit "to the right" of the mark.
HTH..........ed
  #5
Old September 14th, 2008, 08:38 PM
Well plug wires were right. Inside of distributer cap a little dirty, don't have carb cleaner will get some tomarrow let you know how it turns out. Do you think maybe plug wires could be jumping fire got a pretty good jolt when i was checking fire, even had a pair of insulated handled pliers {not very funny ] ha ha thanks again ken Thanks a million Ken
  #6
Old September 27th, 2008, 11:48 PM
You were right distributer was 180 degrees out of time. Runs like a top now thinks everone for your help.Now Ihave no water coming out of hole. Does this mean a new water pump and how hard is that to do.
  #7
Old September 28th, 2008, 12:34 AM
The telltale could be plugged, blow compressed air up the hose or snake a fine wire up there. If it's clear, likely an impeller change will be in order.
Make sure you've got enough water pressure on the flusher, there should be enough pressure to make a bit of water spill past the 'muffs'. This ensures the suction side of the water pump is completely flooded.
Warm water should flow out the middle of the prop. Then you know this water is circulating thru the motor and picking up heat.
The block should never get more than just barely lukewarm when running on a flusher. The exhaust cover should be stone cold (big cover on the Port side aft part of the block).
Plenty of posts here regarding impeller changeout, use the Search feature. Also check the FAQ at the Forums' main page, there should be something there too.
HTH.......ed
  #8
Old September 29th, 2008, 08:03 PM
Yep right again had mudddobber nest in it. Only have a trickle of water at idel but pull fast idel has a pretty good stream of warm water.Faster you run it, water runs out faster so i guess its okay thanks Ken
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
wiring diagram 4 1975 mercury Bigcatchh Mercury & Mariner Outboards 2 February 11th, 2008 05:48 PM
76 Mercury Wiring Diagram 76merc Mercury & Mariner Outboards 9 July 26th, 2007 10:53 PM
Mercury 9.8 wiring diagram sos Mercury & Mariner Outboards 2 March 26th, 2003 05:04 PM
1985 Mercury 850 Outboard Assembly Diagram headen Mercury & Mariner Outboards 0 March 11th, 2003 05:04 PM
wiring diagram 50 hp mercury Rusty B. Mercury & Mariner Outboards 1 February 13th, 2002 04:17 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
