Re: 35hp Mercury Age?
The numbers don't look right.
However, they made two 35's....in the 60's and in the mid/late 80's.
This should narrow it down as far as a manual.
In case you have trouble identifying...
The older model most likely has a Keikhaufer plate on the front of the motor, the choke know protrudes through the top of the cowl, it has a handle on the front/top of the cowl, and the harness connects externally on the left side facing the front of the motor.
The later model is the same as the 40 hp made in the 70's.
