  #1
Old June 17th, 2003, 01:38 PM
motownbob motownbob is offline
Default Paint blistering/corrosion-aluminum boat
I have a 1997 crestliner sportfish. Stictly a fresh water boat, kept on a trailer. Lately i have noticed some very tiny blister like bumps on some of the painted surfaces of the aluminum, especially noticeable around the drains in the transom[splashwell]. Does anyone have any idea on what is causing this? What to do to stop this from getting worse? Thanks, Bob
  #2
Old June 17th, 2003, 04:20 PM
Solittle Solittle is offline
Default Re: Paint blistering/corrosion-aluminum boat
I'm going to guess that you have an electric start motor with battery. If so you may have a small current leak somewhere. No big deal - just disconnect the battery when not using.
  #3
Old June 17th, 2003, 04:37 PM
allanwh allanwh is offline
I have a 20 foot aluminium hull with a 130 hp honda and I am having the same experience.. Paint Blistering around rod holders and where stainless screws penetrate the hull. I will disconnect the batteries as suggested but I have also been told that a sacrificial anode on the hull will help. Can anyone add to this..Thankyou
  #4
Old June 17th, 2003, 10:32 PM
akriverrat akriverrat is offline
yeh. get rid of the paint. it traps water beneath it and rots the aluminum. paint may be pretty but with most aluminum boats it ends up being a liability.
  #5
Old June 18th, 2003, 09:42 AM
Luna Sea Luna Sea is offline
Disconnecting the battery wont help if the battery's not in a box. I learned that one calm drizzly weekend sitting in salt water. Yup, right where the deck meets the back of the boat I got those dreaded pin holes. Current travels through the moisture or something to that effect. Drilled a couple of holes in the hull and added a bolt on zinc. If you do this, lock the studs/bolts in place with nuts and washers, then add the zinc otherwise when the zinc goes you'll start leaking.
  #6
Old February 11th, 2004, 03:34 PM
1sinbad2 1sinbad2 is offline
I am considering a 2000 crestliner Sportfish 1750 and the paint on the aluminum plate around the perimeter of the bow is blistering. Should I just remove the paint and polish the aluminum or install some sort of sacrifical anode. I'm a newby--but is a "zinc" a sacrifical anode? I am not a corrosion engineer. How or where should the sacrifical anode be placed.
  #7
Old February 11th, 2004, 05:35 PM
Bond-o's Avatar
Bond-o Bond-o is offline
Master Shipwright
I just went thru this a couple of years ago, with my 74 Starcraft 221 Islander.......Before I painted my hull, I noticed that anywhere there Wasn't any paint left, I had tons of Pin-Holes...... The Original paint was getting pretty thin over most of the hull....Anyway, I sanded, zinc primed, sandable primed, sanded,+ sanded,+ Shot it with a 2-part Urethane paint..... I then added 3 coats of brushed/rolled Rustoleum, Below the water line........ Being a trailer boat, I now just touch up the bottom a couple times a year, with just a disposable brush....After all this work I found some more pits in some scratches......I found that by Bonding the boat, the Hull should be bonded to the engine, just like the outdrives are bonded to the engine...... This gets everything on a level playing field, so to speak.....Then, You have to Ground All of your Electrical Circuits Directly to the Batteries.......And the Pitting Stopped.....AAnnndddd, The Added Bonus of a Properly Bonded Aluminum Hull(Cabin prefered)........Is the Safety Factor of the Faraday Cage Effect,In case of Lightning Strikes...........
__________________
Any Grease is Better,..... Than No Grease at All.......
NO PM's (Private Messages) regarding boat/engine problems. That is what these forums are for.
They will be Deleted
  #8
Old February 11th, 2004, 06:12 PM
Lark40 Lark40 is offline
I'm reading these posts in amazement.My Crestliner outboard runabout is 45 YEARS OLD! Electric start since new and has no corrosion or leaks whatsoever.And, it runs in semi-salt water (Chesapeake Bay).Add all the zincs that people are recommending, you have some sort of electrolysis problem.Bondo - we also have the same (other) boat. I have no corrosion, but the rivet problem is well known. I'm printing out all your good advice.
  #9
Old February 12th, 2004, 02:43 PM
Bondo--how do you bond the boat to the hull? Can the paint be removed and the aluminium be left unpainted?
  #10
Old February 14th, 2004, 08:11 AM
Bond-o's Avatar
Master Shipwright
???? Boat to Hull,??? 1 in the same isn't it????Go do a Google Search.... It's Really a Very Indepth thing..... BASICLY , Grounding(bonding) Everything Together.....
I have No Idea....I prefer Painted Boats.... Bare Aluminum will Oxidize in a matter of Hours,+ turn Grey......
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Corrosion,blistering on an aluminum boat motownbob Boat Topics and Questions (not engine topics) 3 July 23rd, 2006 07:07 PM
Stripping paint/corrosion from aluminum? CCrew Boat Restoration and Building 9 October 26th, 2003 04:40 AM
Surface corrosion,pitting-aluminum boat motownbob Boat Topics and Questions (not engine topics) 15 August 18th, 2003 07:00 AM
Aluminum boat corrosion aft of battery!!! Luna Sea Boat Topics and Questions (not engine topics) 7 July 29th, 2002 01:46 PM
Aluminum Boat Corrosion Luna Sea Boat Topics and Questions (not engine topics) 0 July 29th, 2002 06:01 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
