Rocky Beem
- Aug 10, 2008
- 3
I have a Force 125 which I have owned for 20 years. It has been running great but I recently ran into fuel problems after refueling (found out it was unposted ethanol). It stopped running almost immediately and would only start after choking and smoked (white) horribly. I switched over to my reserve tank which I did not add to and it ran ok. I have never used ethanol and try to use 89 octane. Now it clouds the dock with white smoke when I idle but will reach top end. I have cleaned out the tank and changed plugs and fuel filters. I'm thinking carb rebuild but in the interim, is there a way to clean the carb? I understand from reading that blending ethanol, reg gas and moisture can produce some kind of gunk.
Thanks
Thanks
