Re: idle speed switch
Are you having idle issuse? Such as it wont idle? I have a 1988 dt-150ss that the switch will not bump up rpm's the usual 50 rpm as per the manual. I've tweaked the idle screws to get the proper 600-700 rpms that are required to idle, but I have'nt seen any tests on this switch to verify that it's bad. So I just deal with it, but it would be nice to be able to test it without spending money needlessly.
