  #1
Old September 11th, 2008, 11:28 PM
Blinkin Blinkin is offline
Question 60hp Mariner: Trouble cranking and idling
This is for my brothers boat so I will try to give as much info as possible.
Mid to late 80's 60hp Mariner engine.
He told me it cranks and runs perfectly at home hooked to the waterhose but when he puts it in the lake it is very hard to get cranked and doesn't want to idle.
I am assuming it has something to do with the pressure being present when hooked to the hose and not when in the lake.
If any other info is crucial for a better response let me know and i will get as much info as possible.
Thanks in advance.
  #2
Old September 12th, 2008, 09:23 PM
CharlieB CharlieB is online now
Default Re: 60hp Mariner: Trouble cranking and idling
I haven't noticed a difference in cranking in vs out of the water but I don't deny that it isn't possible.
Many starter problems are cured with cleaning battery cable ends, both + and - cables, BOTH ends, AND the short cable between the starter and relay. Clean, sand each and every terminal. You are not finished until all are BRIGHT AND TIGHT.
Many idling problems are caused by dirty carbs and/or poor idle mixture.
Idleing on the hose does not require as much fuel as in the water, idle mixtures in the water are often almost 1/4 turn fatter than those set on a hose.
Fatten the idle mixture then reset running in gear once on the water. Adjust to best idle, in gear, plus 1/8 turn. If there is any bog or hesitation on rapid throttling from idle then increase additionall 1/8 turn and retest.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
trouble idling travis37 Johnson & Evinrude Outboards 3 July 17th, 2008 11:45 PM
Compression trouble cranking SNAPPERMG Force & Chrysler Outboards 5 August 12th, 2007 04:09 PM
trouble cranking and flood slug678 Johnson & Evinrude Outboards 2 April 9th, 2006 01:07 PM
Engine sat 3 years - trouble cranking mtammons Mercury & Mariner Outboards 3 April 5th, 2005 05:55 AM
trouble with cranking johnson 175 rcselby Johnson & Evinrude Outboards 0 June 29th, 2002 07:17 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
