  #1
Old September 11th, 2008, 04:49 PM
grock425 grock425 is offline
Default 1980 50hp 4 cyl. Mercury thunderbolt power loss and trigger ?
Hello every one! My engine starts and idles fine but bogs down and dies after a little bit. When this happens i can pump the primer bulb and it powers back up. I had the carbs rebuilt and the problem got worse. I have also replaced the fuel lines. What do I do next. Also, the white/black trigger wire casing is flaking of and the wire has started turning green and brittle. Obviously I need to replace the trigger but what causes this. Are there other parts I need to look at replacing. Thank you for your help.
  #2
Old September 11th, 2008, 11:30 PM
Yepblaze's Avatar
Yepblaze Yepblaze is offline
Default Re: 1980 50hp 4 cyl. Mercury thunderbolt power loss and trigger ?
I would rebuild the fuel pump, probably with a check valve kit, while paying close attention to getting the check valves correctly replaced with new gaskets on a clean gasket surface.
  #3
Old September 12th, 2008, 09:25 AM
Laddies Laddies is offline
If the people that rebuilt the carbs made the problem worst there is a good chance that they are not a reliable service place but I do agree that fuel pump needs attention.
  #4
Old September 12th, 2008, 10:31 PM
Thanks for the advice on the fuel pump. I'll do it myself this time to make sure its done correctly. How about the trigger wires. Does anyone have any advice about that.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
77 merc 500 thunderbolt WOT power loss heat issues kickman Mercury & Mariner Outboards 2 August 6th, 2008 11:49 PM
Power Loss at WOT - 1982 50hp (4 cyl.) imported_Voyager Mercury & Mariner Outboards 1 August 5th, 2008 03:53 PM
1997 5.7 Thunderbolt power loss in drive after warm Boaterguy65 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 May 1st, 2007 07:31 PM
1980 75HP EVINRUDE LOSS OF POWER UNDER LOAD ray j Johnson & Evinrude Outboards 1 April 23rd, 2006 06:55 PM
1980 Merc 50 power loss under stress EMSman Mercury & Mariner Outboards 5 April 28th, 2004 07:20 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
