firefighterco2
- Aug 1, 2008
- 28
Ok so here's the problem. I have recently obtained 20ft pontoon boat with a 50hp johnson outboard. The boat had been sitting unused for about a year. I have rebuilt the carbs and replaced the lower unit grease. The motor now runs great most of the time. It will not idle all of the time. The real problem that I have started happening the other day. The boat was running fine when i shut it off. When I tried to restart the motor it would crank but not start. I finally got it started by removing the cover and and manually opening the butterfly valve on the carb, and spraying some starting fluid in the carb. I have already rebuilt the carbs and used the seafoam that I have read about on here.
1986 Johnson j50belcde
20ft landau pontoon boat
