  #1
Old September 9th, 2008, 10:47 PM
cory0789 cory0789 is offline
Default 82 model 100 evinrude cable stuck help!!!
My buddy has a 100evinrude on his boat but the steering wheel will not turn the motor and its stuck or something anyone know what he needs to do or the easiest way to get it unstuck??? please let me know he just bout the boat for 900 dollars we dont even know if it runs yet but trying to get that fixed we couldnt figure it out today.
  #2
Old September 9th, 2008, 10:59 PM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Default Re: 82 model 100 evinrude
We'll assume he has a push-pull single cable steering. If so, I'd almost bet the cable is stuck in the tilt tube. Kinda common. Take the nut off the drag link and pull it out of the end of the cable. At that point the motor will probably be free.
If so. take the steering cable nut off and try to pull the cable out.
  #3
Old September 10th, 2008, 05:22 PM
truthfully we have no idea what you are talking about... we are only 19 and not much of boat mechanics at all...
  #4
Old September 10th, 2008, 05:30 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Cory welcome to iboats, we even have 15 year old members. disconnect the connection at the front of the motor. will the wheel turn? will the motor turn?
to clairify the tilt tube is the pipe that is in the front of them motor, down where the motor mounts on the transom of the boat.
you are in the right place to get help.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #5
Old September 10th, 2008, 10:52 PM
ok we tried disconnecting both sides on those screw things but only the right side does anything the left doesnt and whenever we tried pushing the pipe through and turning the motor it does nothing... inless we are taking off the wrong bolt... we even sprayed some lubrication on it to try and get it to slip... shook the motor and turned the steering wheel at same time...
  #6
Old September 10th, 2008, 11:20 PM
sorry, do not remove the complete tube. remove the nut that holds the cable, the silver one in my picture. try to work it out of the tube. if it won't move, go to the other side of the motor, an using a block of wood and hammer, wood between hammer and rod, try to knock the rod back thru the tube. do not mushroom the end of the rod, or it will not go thru.
__________________
FLORIDA GATORS
TEBOW Country
  #7
Old September 11th, 2008, 03:58 PM
I will try that this afternoon.. Thanks for the info
Cory
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
82 model 200 cooling problems drummer0901 Mercury & Mariner Outboards 12 May 18th, 2006 02:28 PM
How fast should a 82 Champion 186 with 82 Evinrude V-6 150hp go. Mo.CrappieFisherman Johnson & Evinrude Outboards 38 October 22nd, 2005 03:36 AM
Weight of a 82 Champion 186 With a 82 150 Evinrude Mo.CrappieFisherman Boat Topics and Questions (not engine topics) 3 October 19th, 2005 04:53 PM
Evinrude 100 Model 100293R gribba Non-Repair Outboard Discussions 1 October 25th, 2003 05:18 AM
82 Mercury 90 hp - good model, year? merc Mercury & Mariner Outboards 6 February 8th, 2002 07:18 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
