There's a good chance that I'm going to end up having to replace my exhaust risers, and if I end up having to, I'd almost just as soon replace the whole mess.
I hear the center riser exhaust system flows better, is less susceptible to water flow reversion problems, and they seem to be cheaper and more readily available. I'd rather just replace the whole mess now, and sell the (still good) manifolds to recover some cost. Even if the risers are still okay, I might go ahead and do it now...
Anyway, couple of questions. Obviously the risers are different. What else am I going to have to buy to make these risers mate up with my Y-pipe? Is there anything else involved in doing the swap?
Also, is it better to go with aluminum or cast iron? I'm thinking Aluminum would weigh less, last longer, and dissipate heat better.
Is there a reason that Aluminum ones are less common?
