Re: 2000 mercury 40hp 2cyl 2 stroke running and starting problems
When you finish for the day, do you unplug the fuel line and let it run out of fuel? If so, that's why you're having problems... By running it out of fuel, you're filling the carb with oil, hence the hard starting and very smoky.
Dieing with either plug lead remove I would consider normal....
Chris........
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
