long tooth
- Aug 7, 2008
- 5
Hi, everone. This is my frist post and I searcded, but didn't find an answer. I have a 1981 9.9 Johnson that I replaced the impeller on because it was not peeing. Works great now: peeing fine, however I think I don't have the shift rods connected correctly. When I disconnected the upper and lower rod at the upper screw on the brass fitting connecting the rods, I failed to notice how far the uper rod goes in the the fitting. The upper rod has a grove about 1/4in from the end. I can not make this grove go below the top of the fitting.Also I noticed that there is a slight rearward bend at the last 1/2in of the upper rod that makes mating the rods difficult. Is this normal? When I do get them connected, it will only shift into neutral and reverse. I don' think I let the lower rod rotate any when I installed the impeller.
If anyone should enlighten me relative to the upper rod ldepth in fitting, or is upper rod bent, and how totell if lower rod is adjusted to the right length, I would appreciete it.
