Re: Mercury 1150 Ignition Help
to help diagnose this theres a few questions that needs to be answered: first and foremost, how good is the battery your using, did it have ample charge? the reason this answer matters so much is the fact that you stated at one point it wouldn't even crank...why did it not crank, was the battery drained from trying to start it so much...or was the battery still charged, did you have to get a jump-start to get it to crank when it wouldn't? look at it like this, if the battery had a good charge and wouldn't crank, then you have an electrical issue...and no its not the coil, the coil provides spark to the plugs and even if it went bad, with a good battery you still should have been able to crank the motor...the coil does not charge the battery...and because of all that you've said, it doesn't sound like a fuel issue either...fuel pressure doesn't stop a motor from cranking...im guessing you have a bad internal wiring harness, these older motors are notorious for that! generally what happens in the case of bad wiring is cross-firing between conductors due to crumbling insulation on the wires! when this occurs the wire strands become superheated and will break-down to the point where they will no longer conduct electrical current...until they cool down, and then they may let some electrical current flow again, until they start shorting-out again, then they breakdown again because of the heat! check that wiring harness!
