  #1
Old September 8th, 2008, 10:56 AM
Bigbobcat Bigbobcat is offline
Default Questions: 2006 Mercury Bigfoot 4 Stroke EFI 40 HP
Hi,
I am looking into buying a pontoon boat with a 2006 Mercury Bigfoot 4 stroke EFI 40 horse power motor. The pontoon boat was used for 2 seasons (2006 & 2007) and winterized in the fall of 2007, not used since fall 2007 and now sitting on 4 concrete blocks.
How can I check this engine if (a) Launch it to the lake and test drive it, what to check ? (b) On the ground, what to check ?
Any input is appreciated (NEED INPUTS ASAP), please give more details and use plain language as I am new to boating.
Thanks
  #2
Old September 8th, 2008, 04:42 PM
chrisg chrisg is offline
Default Re: Questions: 2006 Mercury Bigfoot 4 Stroke EFI 40 HP
BigBobCat, first off, I just noticed you are new here, so welcome.
The is LOTS of good info on this site, just have to look. I asked a simular question not long ago, got some good advice. I dont know how to link to a thread, but when I find it, I'll let you know the location.
__________________
Chris
Gave up on searching for a lake in Iowa!
  #3
Old September 8th, 2008, 04:47 PM
my posting is called "Help with buying a motor from Classifieds please" and under the mercury/mariner forum, a while ago, so you will have to look through some pages. Are you buying from an individual, or dealer?
I got some good advice with checking out the motor, but basically check for physical damage, condition of prop, take it out for a run, check compression, check lower unit oil condition, etc.
__________________
Chris
  #4
Old September 8th, 2008, 04:57 PM
Hi Chris,
Thanks !
I haven't found the thread you suggested but will try to find it again.
There is no physical damage to the Merc Bigfoot 4 stroke 2006 motor, I will do a test drive, but how can I check the compression & lower portion of the motor ?
Thanks
  #5
Old September 8th, 2008, 04:59 PM
How can I check:
(1) condition of prop
(2) take it out for a run, then check for what ? Noise ? What am I expecting for a 2006 Merc Bigfoot ? What to look for ?
(3) check compression, how ?
(4) check lower unit oil condition, how ?
Thanks !
  #6
Old September 8th, 2008, 05:08 PM
Oh, I am buying it from an individual, not from a dealer !
  #7
Old September 8th, 2008, 05:27 PM
For the prop, physically look at it if it has dings, bent, etc. Compression requires a compression tester and someone with knowledge. (I'm taking the engine I'm looking at to a marina to check over, as it cant be started without hookups ( not on a boat). Otherwise take it out and see how it is.
I found the thread:
http://forums.iboats.com/showthread.php?t=273806
Also, check out the NADA web site to check prices of used items ( boats and motors) http://www.nadaguides.com/
Also, a 2006 is not that old, so they may be OK If they run.
As a side note, instead of adding more replies, there is an edit button to add more stuff to your reply. If now I can just know what to do to add the emoticons inside the text body!
Just in time to put them away for winter!
__________________
Chris
  #8
Old September 8th, 2008, 05:46 PM
Hi Chris,
Thanks ! I just found the thread too, it was hidden at page 11 of Merc/Mariner Outboard ...
It's a 2006 Merc Bigfoot 4 stroke 40 hp, the most the owner would allow me to do is to test drive his pontoon boat, I am not allowed to take the motor out to the marina to have it checked out
So I hope it will be ok after test drive it. But what noise or how quiet am I expecting ?
Also, I am planning to crank up the speed (high rpm) to see if it runs smoothly, any thought ?
Thanks !
  #9
Old September 8th, 2008, 05:48 PM
Also, not to scare you, but the pontoon I bought, the motor had internal issues ( it was old also) I did not know untill I took it in for hard starting. you can read my Sauga (SP!?) in the forum.
__________________
Chris
  #10
Old September 8th, 2008, 06:07 PM
Quote:
Originally Posted by Bigbobcat View Post
Hi Chris,
Thanks !
I would think 40HP is small for a pontoon. All the pontoons I saw that are small are being run at full throttle just to get them to move. I would think that that would cause the motor to wear ou faster. But you will have to wait for others with more knowlage on motors to answer that. Give it a day or so for others to pipe in.
Good luck, Been there, did that.
__________________
Chris
  #11
Old September 8th, 2008, 06:52 PM
Silvertip Silvertip is offline
Condition of the prop: Look at it! Bent, folded over, pieces missing = bad.
Lower Unit Oil Condition: Look at it! Remove the drain screw and check what comes out. Water = bad. Chocolate color = bad. Oil color = good.
Compression: You need a compression gauge.
Engine Oil: Its a four stroke just like your car. Pull the dipstick and check it. Low = bad. Dark oil = bad (lack of maintenance), Clear oil = recently changed, over full = idiot didn't read the manual.
Don't need to splash it to run the engine. Hook hose to muffs and start it. Any alarms immediately or after warm up? If so = bad. If not = good.
Then test drive just like you would a car. Knocking, clicking, chugging, failure to start, failure to idle = bad. Good hole shot, good speed proper RPM at wide open throttle = good. Don't buy the story when the owner tells you it just needs a simple adjustment and it will be perfect. That simple adjustment generally turns out to be not so simple and costs you a ton.
  #12
Old September 8th, 2008, 11:20 PM
Hi Silvertip & Chris,
Thanks a lot !
Here is what I know: The pontoon boat was winterized in fall of 2007, on 4 concrete blocks since fall 2007, ground pole of battery was sitting at back of pontoon boat and disconnected.
Looked at it, no bent or folded over or pieces missing
I don't know if the owner will allow me to remove the drain screw or not but will insist on checking it before paying
How can I do it ? I don't know how to do it
I will check the dipstick and check it as you said. But it was winterized in fall 2007 and never back to the water since fall 2007, what colour of oil will I expect in this condition ?
The owner will have someone to run the engine with hose to muffs, I THINK !
I only recalled he said his people will run a hose or something to test the engine on land (not on water).
How long or how many minutes should I let the engine run before I will know the engine is good after warm up (ALARMS) ?
Question: In what situation will the engine alarm ? Overheating ?
Will check those. Failure To Idle, does it mean it when it is in neutral, it dies ?
- Knocking, clicking, chugging: At what speed ?
"Good hole shot": Can you explain ?
"good speed proper RPM at wide open throttle": Can you be more specific ? Any example ?
I will keep this in mind !
  #13
Old September 9th, 2008, 09:45 AM
Compression gauge screws into a spark plug hole. You spin the engine over on the starter and the cylinder pressure (compression) is read on the gauge. All cylinders should be well over 100PSI and within 10% of each other on a good engine.
Hole shot: Hitting the throttle, the engine should respond instantly with no lagging or misfire, coughing etc.
Lower unit repairs are expensive. If he won't let you remove the screw, have him do it. Place a small container under the lower unit and remove the plug for just an instant. 1/2 oz of fluid loss is all it will take to tell if water is present or the lub is discolored. If water comes out (any amount) the lower unit is leaking and needs seals.
Engine oil is the same color as the oil in your car. Nearly clear when new to dark when used.
Alarms sound for low oil pressure (really bad situation) and overheat (not good either). Overheat can generally be fixed with a new impeller, thermostat, and bypass valve. Overheat alarm should sound in less than five minutes at idle but it can also occur at high speed and not at idle.
Any boat with any engine combination requires a propeller that allows the engine to run at or near the manufacturers recommended wide open throttle rpm. For your engine that is 6000 RPM. So with an average load running wide open the tach should read somewhere between 5500 and 6000 rpm. If it reads less than that, the prop is wrong or the engine is not making full power. Chances are its a wrong prop. If the engine revs higher than 6000 rpm the prop is also wrong and requires more pitch.
Good speed on that boat will be in the 18 MPH range with a light load. I have an 18 foot four-corner fish with a Suzuki 40 four stroke and it performs just fine. If you are after speed, doubling the HP will likely get you into the mid 20 MPH range and double fuel useage. I cruise very comfortably at 4400 - 4800 rpm so no, you don't need to be wide open to make headway.
  #14
Old September 10th, 2008, 03:26 AM
Captain Trips Captain Trips is offline
You might want to check and see if the motor is still under factory warranty also. I bought a toon this summer with a 06 90 hp and am still under the three year warranty on merc 4 strokes. All I had to do was log onto their web site and ask how to transfer...quick and easy!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2006 60 HP 4 Stroke EFI impeller problem??? mnfishing Mercury & Mariner Outboards 3 April 20th, 2008 12:45 AM
2006 Mercury 115HP EFI 4-Stroke - How strong should it pee? TheChad Mercury & Mariner Outboards 6 June 5th, 2006 07:13 PM
New 2006 Mercury 115HP 4-Stroke - Questions about Additives TheChad Non-Repair Outboard Discussions 2 April 10th, 2006 04:55 PM
Mercury 40 4-stroke EFI benelli Mercury & Mariner Outboards 2 June 17th, 2003 04:47 PM
Mercury 40 Four Stroke BigFoot Noise haggertb Mercury & Mariner Outboards 5 June 14th, 2002 01:10 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
