Re: removing 65hp 1970 merc from engine mount
Dave,you might want to post on Merc site.BUT.Be sure to remove the steering,then heat the housing that the steering arm runs through.It takes alot of heat and oxy acetalene is about the only way to get the whole unit hot from top to bottom
