  #1
Old September 7th, 2008, 07:30 PM
captainnelson captainnelson is offline
Unhappy rpm and temp gauge on 90 Evinrude 140hp
Hi i got a 90 Evinrude 140hp v4, my rpm and temp gauge not working
how i need to do to replace it?. I already check the cables and they are okay.
wich cables i need to look at the engine?
thanks in advance.
  #2
Old September 7th, 2008, 07:38 PM
ezeke ezeke is offline
Default Re: rpm and temp gauge on 90 Evinrude 140hp
Temp gauges are aftermarket or accessory with variable resistance senders mounted on or in the cylinder heads. The sender in the cylinder head must be the correct one for the gauge and must be thoroughly grounded.
In the looper 140, the sender will be inserted in the left side of one of the cylinder heads and have a tan wire. The tan wires are also used on temperature warning switches in the cylinder head which are mounted on the right side of each head.
Very often the tachometer is not working when the rectifier is bad. Test the rectifier according to Mr. Reeves methods in the Engine FAQ Forum. Also check the rectifier's charging by voltmeter at the battery when not running vs. running.
http://forums.iboats.com/showthread.php?t=190636
  #3
Old September 7th, 2008, 07:50 PM
kenmyfam's Avatar
kenmyfam kenmyfam is offline
Rectifier for tach.
Do not have water temperature on my 140hp Looper. I do however check it with the gun thing on occasion.
Welcome to iboats.
__________________
1985 Doral 164 1985 140hp Johnson EZ loader single axle trailer all = a whole lot of family fun !!!!
Windsor Spitfires. Memorial Cup Champions 2009
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Johnson,Evinrude V4 90-140HP j140head Johnson & Evinrude Outboards 7 February 9th, 2008 01:57 PM
Adding a temp gauge to Evinrude 70hp onehunglow Johnson & Evinrude Outboards 25 September 23rd, 2007 04:53 PM
Need info for wiring temp gauge/ 115hp Evinrude calm like a bomb Johnson & Evinrude Outboards 3 January 21st, 2006 04:52 PM
1993 Evinrude 225hp temp gauge reading wrong dbw1356 Johnson & Evinrude Outboards 1 July 19th, 2005 01:33 PM
How to install a temp gauge for a 71 Evinrude 65 hp Texas Heat Johnson & Evinrude Outboards 3 June 17th, 2003 11:05 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
