Re: Strengthen Transom?
post # 385 in the hull extension thrread has a photo.......i know theres a better one of them but i missed it....(if you have a page format....its on page 16)
you could easily do this at the point you are at....
...bear in mind......all of this stuff is way over kill.....read ondarvrs post about it being good..."then its good"....the general rule of thumb....is duplicte what was there.....the manufacturers over built your boat in the first place....by glassing in the wood stringers....adding more to the transom...you are really beefing it up so much that it will probably never need the stregnth your adding
...(btw) adding another layer of glass to the transom....will just thicken it...and not do you much good..(as it will be only as good as the origonal bond to the plywood)..but if you wrap the glass around the back of the hull by a good 6 inches..(tabbing)...(see hull ext)..you will get the extra stregnth you are looking for......remember any glass that you add....you will need to rough & scuff the orgional glass...
hope that mess of thoughts helps
