  #1
Old September 7th, 2008, 05:04 PM
mmf mmf is offline
Default Mercury 500 carburetor change
1968 Merc 500 (50HP) serial #2407450, my carbs on this motor have alot of wear. I have 3 Tillotson KC7A carbs in good shape from a 1969 Merc 115 engine. The 115 carbs have 0.066 jets while the Merc 500 carbs have 0.063 jets. The bore on the 115 carbs is a little larger than the 50HP carbs too.
Do you think I will run into any problems running the 115 carbs on the 50HP engine if I change the jets to the 50HP size??
Thanks!
  #2
Old September 7th, 2008, 05:27 PM
Yepblaze's Avatar
Yepblaze Yepblaze is offline
Default Re: Mercury 500 carburetor change
I've never really taken any of these old merc carbs out of service for wear.
But that being said, it sound like you have a plan.
Let us know how it works out.
  #3
Old November 5th, 2008, 06:27 AM
mmf mmf is offline
sorry for the very late update but the carburetor change worked great!
Idles perfect, and good high speed operation. Thought I might run into a little air turbulance problem due to the larger venturi bore but that never happened.
  #4
Old July 28th, 2009, 11:51 PM
troubledboatdude troubledboatdude is offline
i have a 70 500 50 hp...im wondering if you can help...just got it, it was running great at idle and wide open but seemed to lack fuel inbetween. now 1 week later runs great in neutral but when in gear seems to starve for fuel if i can feather it nicely a little tap on the choke button will keep it from starving, it will go smoothly in gear at idle...has great spark lots of compression (top 120 psi,2nd 120 psi 3rd 120 psi, 4th 122 psi)...and if it is carb i used to be an auto mechanic but never touched one of these,how do i get the carbs out of this? (im very sry to post this question on your post you just seem fairly knowledgable in this area)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
when to change timing belt on 500 50hp dave37 Mercury & Mariner Outboards 4 October 25th, 2007 08:18 PM
76 Mercury carburetor Kelley523 Mercury & Mariner Outboards 2 July 9th, 2005 11:34 AM
Mercury Carburetor floats CaptJackM Mercury & Mariner Outboards 2 April 25th, 2005 06:03 AM
Mercury 9.9 carburetor Papa Joe Mercury & Mariner Outboards 3 July 28th, 2004 04:17 AM
1970 Mercury 500 Carburetor Leakage indy82tx Mercury & Mariner Outboards 3 March 9th, 2003 06:18 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
