  #1
Old September 6th, 2008, 05:46 PM
golfrbob2 golfrbob2 is offline
Default Mercury 650 ignition issues--UPDATE
I have a 1968 Mercury 650. I can get the boat to start by using the battery and jump starting the starter with jumper cables, bypassing the solenoid and the ignition key. Boat will start and run.
However, when I try to use the key, the starter does not turn over. I bought a new solenoid and replaced that. I have tested it in the following ways:
I put the positive of the voltmeter onto the positive of the solenoid. When I turn the key, I get 12 volts. However, this is with the grounded side of the solenoid not hooked up and the negative side of the voltmeter connected to the negative on the actual starter. However, when I connect the grounded side of the voltmeter to the grounded side of the solenoid while it is grounded, I get no responseat all . I hhave to ground the voltmeter to a separate ground, which I find odd. Otherwise, when I turned the key, I do get 12 volts. I don't get anything coming out of the yellow starter cable however.
It is almost like the ground side of the solenoid is not working properly to allow the solenoid to open. Using alligator clips I have tried grounding it to everything on the engine and when I connect the negative on the voltmeter to the negative on the solenoid or on the alligator clip where I have grounded the solenoid, I don't get any voltage.
UPDATE:
When I connect the solenoid ground to the battery ground, the solenoid will open, but the starter did not turn over. Then I connected the starter ground to the battery ground and it fired up with the key.
Any ideas why I can't get these two cables to ground out? I have tried connecting them to every part of the engine cowling.
  #2
Old September 6th, 2008, 09:12 PM
bhile's Avatar
bhile bhile is offline
Default Re: Mercury 650 ignition issues--UPDATE
The cowling is not a ground. You must use the engine block. If it still doesn't work, temporally run a jumper cable from the NEGATIVE post of the battery to bare metal on the block. You may have a bad ground cable.
__________________
Fair Winds and Following Seas
Bill
PTC USN ret
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Merc 650 ignition OCboat Mercury & Mariner Outboards 2 April 28th, 2007 03:15 PM
66 Merc 650 ignition nos1013 Mercury & Mariner Outboards 6 May 2nd, 2006 07:02 PM
'73 Merc 650 ignition problem virgilturtle Mercury & Mariner Outboards 7 March 29th, 2004 03:40 PM
1971 mercury 650 thunderbolt ignition concern rc2 Mercury & Mariner Outboards 2 September 18th, 2002 02:07 AM
Mercury 650 tbolt ignition hdawg Mercury & Mariner Outboards 10 September 9th, 2002 11:39 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
