  #1
Old September 6th, 2008, 05:10 PM
GWDolphin25 GWDolphin25 is offline
Exclamation 2003 Yamaha HPDI 250 - Not Firing in #2 & #3 Cylinder
Hi everyone!
I'll thank everyone in advance for posting answers and questions in these posts. I find them very helpful. I am not a certified Tech so forgive me if I use incorrect terms.
I have this HPDI with a freshly rebuilt powerhead. The injectors were ultrasound cleaned and tested. Spark plugs are new. The engine oil lines were primed correctly and everything is injecting as it should.
The engine fired up and idled beautifully for about 10 minutes so I shut it off. I then got the Yamaha Diagnostic Software and plugged the motor up to the computer to see the engine monitor and run diagnostics. When I did that, the system showed everything to be normal but now the engine missed badly and I found that the #2 and #3 Cylinders were not firing. The monitor would go to YES as it cranked and did the initial fire then it would go to NO, stay at NO and miss, eventually stalling. I checked and changed the coils and cables and checked all connections and spark plugs. Everything seemed normal.
I don't know where to go with this and any help would be great. Thanks!
  #2
Old September 6th, 2008, 06:06 PM
Default Re: 2003 Yamaha HPDI 250 - Not Firing in #2 & #3 Cylinder
I Googled and found out after this post that the HPDI 250 drops out the #2 & #3 at low or trolling rpms. Excuse my ignorance! I still think the engine is idling too rough for me.
This motor threw a rod after over 1600 hours. I guess this was one of the good ones...or one of the lucky ones. It's run over 1100 hours in the 3K-4K rpm range and about 350 at about trolling speeds. Just some info.
Thanks again.
  #3
Old September 7th, 2008, 02:20 PM
rodbolt rodbolt is offline
your close,still no seegar.
at idle in nuetral the Z motors drop cylinders 2-3,in gear ALL 6 hit regaurdless of engine speed until the rev limiter gets you.
during cranking all 6 cylinders fire until the engine is running then the ecu looks at the shift switch position and determines is it in nuetral.
if ya really want to watch something silly,throttle it up in N and you will see 2 more cylinders drop off as engine speed approaches 1800 or so.
whats amazing is the amount of folks,both online and in the shop,talk about it will hit 4000 RPM in Nuetral on 2 cylinders.
however I can never see a reason to throttle up an EFI or DFI motor in nuetral.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
250 Hpdi 2003 WRECK Yamaha & Suzuki Outboards 2 December 31st, 2007 05:59 PM
250 hpdi yamaha 2003 WRECK Yamaha & Suzuki Outboards 3 December 28th, 2007 10:39 PM
250 yamaha hpdi 2003 WRECK Yamaha & Suzuki Outboards 1 December 26th, 2007 01:41 AM
250 HPDI Yamaha 2003 gretchenfalk Yamaha & Suzuki Outboards 7 July 23rd, 2003 10:50 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
