fluidjuice
- Jun 12, 2008
- 54
Mercury 1990 40hp oil injection.4 cylinder twin carbs
I have been having a lot of the same problems ie been going round in circles for the last month.
so i need someone with a clear head to refresh me and give me some straight info.
when under load engine stalls when put in gear and revved.
Thanks to laddies ive stripped and cleaned carbs ,
ive also put new fuel line on powerhead etc.
new inline fuel filter.
as said befor spark and comp tests good.
my trouble is that on muffs engine will idle but plugs have been found to be oily but i put that down to the idle mixture not being set up at the moment.
But on occasions the lower two cylinders dont seem to be firing .( removing spark leads dont make any difference.
if i squeeze primer bulb engine picks up and also if i spray fuel oil mix into bottom carb it also picks up .Spray it in the top one and it stalls?
so presumably no fuel to lower two cylinders.
Would i be wright in thinking that this is due to oily spark plugs and they are grounding out????.
but top two plugs are oiled up too.and cylinders seem to be running.
I have adjustment on top carb idle screw but nothing when bottom carb idle is turned.
so my question is what could be the prob if ____
1 ,i have good compresion.
2 ,good spark even when unlugged the leads ground out on the side of engine and jump nearly half inch.
3,carbs are clean thanks to laddies expert help.
4 fuel lines are clear and so is filter /
5, Tank is vented well
Is this a fuel pump diaphram prob , has anyone seen these symtoms before. if so i would be GRATEFULL for any info as i seem to be going around in circles and am getting VERY dizzy.
