Yamaha 150TLRB '03 model. The oil tank is being overfilled. This is an intermittent problem. It seems to happen more often when the motor is run at alternating midrange and idling speeds as when pulling a tube. The raw 2-cycle oil overflows the main oil tank (on the motor) and just accumulates under the cowling. The float on the switch inside the tank seems to move freely. Any suggestions?
Thanks
Thanks
