Steve Mahler
- Oct 10, 2006
- 361
I have a lark I have been tinkering with; with a new fully charged battery, jumping direct with jumper cables, I only have enough 'electric power' to slowly crank over the motor. Compression is good - I am no muscle man but I can pull crank the motor over OK, maybe 3 or 4 revs per manual pull.
So, is it common that the starter is weak? My experience they are all or nothing. There is no visible corrosion on this engine, so I think connections are clean - I moved both pos and ground around with no change in cranking power.
thoughts?
thoughts?
