MCM 120--Bellows, transom or what???
jacko137
I have a 1977 MCM 120 mated to a one drive on a 19' fibergalss runabout (same year).
Here's my thing:
I restored the boat over the winter (first timer)--engine runs good, shifts well, cools, etc. and the boat is looking good. I took her for the big first launch and she took on probably 10 gallons of water inside 10 minutes. I pulled her and found a torn shift cable bellow (torn very neatly all the way around within a fold so it wasn't easy to see damage).
Also, when I pulled up on drive the water poured out underneath gimble plate (viewed from outside), so I figured maybe rotten transom as well (though it sounded solid from inside when knocking). So I pulled the engine for further inspection only to find that the ENTIRE gimble assembly on the inside of the boat was loose--I mean washers floating behind nuts loose??? So, I tightened everything down and no give and it feels solid now when pulling up on drive (no give).
THE QUESTION: The real question is why would someone loosen all the gimble plate nuts and leave them like that, but I'm looking for suggestions from you guys on how I might seal that shift bellow back together. It is a nice clean tear all the way around. Maybe glue it and wire wrap it to releave stress at tear? I figure if I can temporarily fix shift bellow, I'll keep engine pulled and put drive back on and see if she's still taking on water and from where. If not, I'll put engine back in, outdirve on and fix all bellows properly and hopefully have a nice little boat.
Does my approach make any sense to you fellas? :confused:
Fishermark
Re: MCM 120--Bellows, transom or what???
In a word - NO.
The shift bellows is easy to replace and needs to be. Forget trying to patch it. The chances are good that your drive bellows needs to be replaced as well.
Again, forget trying to patch or otherwise "get by."
The loose bolts / nuts would suggest the transom has gotten soft. You really ought to pull the entire transom assembly and replace the seal under it. You can get a better fell for the transom and its condition then.
Good luck! ;)
Ayuh,.....
It's only another 6 Nuts,...... ;)
jacko137
Ayuh,.....
Yeah, but don't I have to disassemble everything attached to the plate on the inside of the boat as well to remove the gimbal housing--steering assembly,etc? If it's really just six bolts, hell you are right. I already have the engine pulled.
So if the loose gimbal plate was the result of swelling/expanding transom wood, is it a certainty that it will rot? I tightened that thing down pretty hard and the wood didn't give. It is solid where wood is exposed (steering control cavity, etc).
daydreamer1252
My 2 cents....take it off and inspect. My transom was seemingly solid too :mad: NOT!! When all was said and done the remaining "wood" was more like parchment paper than anything resembling wood. Immediate area around the transom cutout was not too bad, thought I might get by with a patch :rolleyes: no way.. Hope you fair better. But I do encourage you to check thoroughly ;)
