saltshaker
- Aug 11, 2007
- 7
sounds like i may have a simial problem to some already posted here.
I have a 1989/1990 Evinrude 225, been running great. Was about half throttle getting up on plane a week ago, a minute or so later, i was stopped in neutral. seems like all of a sudden the engine shifted to neutral, but the trottle was still "forward". The engine was still running, pee hole working, everything looked normal. shut down the engine, lifted it, no visible damage (i'm pretty sure i didnt hit anything). i dont even think i heard a noise, just slipped into neutral or, slipped out of gear. Looked at it closer the next day, shift rod looks fine, moves up and down. Engine runs fine, but would not go into forward or reverse. Throttle shifts, engine will not start with throttle in gear, so its like the engine knows its supposed to be in gear, just doesn't actually engage.
i'd like to haul the boat and drop the lower unit myself to see what im dealing with. is it very difficult? can someone recommend a book for this, seloc? i figure worse case im looking to replace the lower unit. but maybe it could be a quicker/cheaper fix?
I appreciate any responses, thank you.
