  #1
Old September 4th, 2008, 02:15 PM
DON MAS DON MAS is offline
Angry Evinrude Sportwin Lower Drive
I HAVE 2 EVINRUDE SPORTWIN OUTBOARDS..ONE IS A MODEL#9022C SER#E-00001 [YEAR UNKNOWN ]WHICH HAS A BAD ENGINE AND THE OTHER ONE A MODEL #9822D SER #E-17788 [1968] WITH DAMAGED LOWER DRIVE GEARS. BOTH HAVE SHORT DRIVE LENGTHS....I WOULD LIKE TO KNOW IF IT IS ACCEPTABLE TO INSTALL THE GOOD UNIT WITH THE BAD UNIT [BOTH LOOK THE SAME] AS A SWAP OR ARE THE DESIGNES NOT THE SAME. FISHING IS GOOD AND I AM STUCK ON SHORE...MAYBE I SHOULD INVEST IN A NEW SET OF OARS INSTEAD.....AN IDEAS OUT THERE.
  #2
Old September 4th, 2008, 02:40 PM
samo_ott's Avatar
samo_ott samo_ott is offline
Default Re: Evinrude Sportwin Lower Drive
I don't know the 9.5's very well but the 9822 is a '68 and the 9022 is a '70. unless others weigh in I would expect them to interchange as most other LU's do on the other same hp series. Worst case scenerio, it shouldn't hurt to try it, that's what I usually do and it it fits well and doesn't seem to bind anywhere then it's probably good. And make sure it's pumping water after.
__________________
Steve.
  #3
Old September 4th, 2008, 03:04 PM
iwombat's Avatar
iwombat iwombat is offline
They'll interchange just fine.
  #4
Old September 4th, 2008, 04:44 PM
Thank You For The Info..this Makes Things Look Much Better.....don
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Lower Drive oil 55hp Evinrude Rodneys Johnson & Evinrude Outboards 7 July 5th, 2009 10:44 PM
Evinrude 10hp Sportwin lower unit question LKaras1 Johnson & Evinrude Outboards 2 August 25th, 2008 08:31 PM
1968 9.5 sportwin lower unit pfaasse Johnson & Evinrude Outboards 3 August 10th, 2005 10:58 AM
1958 Evinrude Sportwin has creamy oil in lower unit mologus Johnson & Evinrude Outboards 3 September 12th, 2003 05:23 PM
Evinrude 8HP Cannot seperate lower drive from powerhead dpowell2 Johnson & Evinrude Outboards 3 June 15th, 2003 07:01 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
