  #1
Old September 3rd, 2008, 10:26 PM
Terryc90 Terryc90 is offline
Default Minn kota 65lb thrust problems
I have a minnkota 65lb thrust 24volt trowling motor aproximately 3 years old.
the problem is there is no forward movement when you put it in forward it only goes in reverse as well as in any gear does anyone have a solution?
What could be the problem??
  #2
Old September 3rd, 2008, 10:55 PM
Silvertip Silvertip is offline
Default Re: Minn kota 65lb thrust problems
Battery cables reversed perhaps. This is a 24 volt motor so two batteries are required and they are wired in series. Have those batteries or the wiring been messed with lately? Here is what it should look like.
  #3
Old September 4th, 2008, 12:23 PM
that is the way it is wired and it was just recently purchased. Could it be a switch problem?
  #4
Old September 4th, 2008, 12:33 PM
AZMinyard's Avatar
AZMinyard AZMinyard is offline
I had a similar problem with the Minn Kota that came with my boat - it would only run in reverse, not forward. The clamps where rusted, causing a bad connection. I corrected this any have not had an issue since.
Just a thought, could be a switch problem as well.
  #5
Old September 4th, 2008, 02:58 PM
I assume this is hand controlled motor so there is a FWD-OFF-REV switch on the head? If so, it is very likely a switch problem. That switch is easy to replace (take a picture before disconnecting wires). Remove the old switch and install the new one. The switch can be tested if you know how to use an ohm meter. And if you know how to use an ohm meter you don't need me to explain how to test the switch.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Minn Kota Riptide, what thrust ? Help sv310 Non-Repair Outboard Discussions 1 June 28th, 2004 10:18 PM
Minn Kota Riptide, what thrust ? Help sv310 Electrics, Electronics and Trolling Motors 1 June 28th, 2004 10:18 PM
MINN KOTA THRUST VS HORESPOWER stingerstang Electrics, Electronics and Trolling Motors 1 October 27th, 2003 10:10 AM
Minn Kota turbo 36lb thrust trolling motor problems joltenjoe Electrics, Electronics and Trolling Motors 0 June 18th, 2003 08:19 PM
Minn Kota 50 lbs thrust , Ok as a kicker?????? wa3ipb Non-Repair Outboard Discussions 6 August 15th, 2001 04:50 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
