I have a 1977 115 hp 2 stroke Johnson Outboard. It has sat dormant for more than six years; that is until yesterday. After a long wait, I replaced 3 ignition coils, rectifier, spark plugs, new fuel in carbs and tank. We took it out on the water yesterday for a test run. It did run, but every time we tried to throttle up to a high rpm, the engine would die. If I removed the cover, and manually advance the throttle quickly past the dead spot in nuetral, it would rev up no problem, but trying to use the control unit to increase rpm's in gear would not work. So I dissassembled both carbs yesterday, carefully removing and inspecting all orifaces, but there was no noticable obstructions. ?? Can anyone tell me what would cause a dead spot while trying to incease rpm's???
Thanks for any help!
