Upper Gear Housing Gear Ratio
JaredEm
Hey guys,
I have a '91 3.0L motor with a mercruiser Alpha One Generation II (I believe) outdrive. I did the worst idiotic rookie mistake and didn't check all the fluid levels before I took her out on a run.:mad: Fried the upper bearings to where they got thrown into the gears and basically seized everything. Any Ideas of what else I could have damaged? From what it looks like I have to replace the upper bearings, gears (19-17 tooth, #'s on gears 3765/75325-1, 3755/75324) seals, gaskets, etc. When I looked on the web found some gears from quicksilver that have different ratios closer to if not 1:1. The tach has been reading that it revs high (Previous owner). Could I simply replace those gears with the closer ratio gears and not have to worry about anything else? I would appreciate any help since I know JACK about boats.
Don S
Re: Upper Gear Housing Gear Ratio
Every drive I have ever rebuilt that had the upper gears go like that, always had damage to the gears and bearing in the lower also. They share the oil.
Ayuh,.... Welcome Aboard to the forums here at iboats,...
There's Much more to it than just switching those Gears,.....
I suggest you look into a Brand New Replacement,...
The SEI aftermarket drives are Cheaper than having Your's Rebuilt......
Btw,...
Your motor requires the 1.98:1 overall Gear Ratio....
