  #1
Old September 3rd, 2008, 11:45 AM
pmcs pmcs is offline
Default Need Head Torque specs for older 8HP Mariner
Hey Folks,
I have a Mariner 8M, Serial Number 677S 035288 (Yes, that is an "S", not a "5") From what I can figure out, the year built is 1980.
Had to pull the head for a water passage problem. Tried to put it back together and started snapping off head bolts. I've got a manual for 1990 or newer mariner that says the head torque is 60 FT LBS. Based on the breaking of the bolts and the size, this can't be right.
I am going to tap the head holes to the next size (1/4") and need the correct factory torque specs for the head bolts.
Thank You in advance,
Eric
  #2
Old September 3rd, 2008, 04:12 PM
emckelvy emckelvy is online now
Default Re: Need Head Torque specs for older 8HP Mariner
Eric, that must be a misprint, more likely 60 Inch-Lb is correct for that size of bolt.
Note, when in doubt, you can consult generic S.A.E. fastener torque charts (just Google it up) to see if the torque value given seems to at least be within reason.
Approx 70-80 Inch-Lb would probably work for 1/4" fasteners.......ed
p.s. multiply Ft-Lb by 12 to get the equivalent in In-Lb!
  #3
Old September 4th, 2008, 10:56 AM
Actually, my initial torque was 120 inch/LBS (10 Foot/LBS)
that is right were the bolts started to strip and/or break off.
I wish I had access to an original manual from that year and could check the torque.
At 120 Inch/LBS, the gasket wasn't really seated competely based on visual inspection after removal.
My guess is that the torque should be greater than 120 Inch/LBS and lower than (60 Foot/LBS). I think that corrosion has weakened the threads on some of the holes, hence the stripping.
If anyone has a manual from that year, can you please report on the factor head torque spec?
Thanks in advance,
Eric
Ps This is an outboard made by Yamaha for Mariner...
  #4
Old September 7th, 2008, 10:27 PM
Well folks,
Here is the final resolution...
Found two manuals that quote 60 Foot LBS and 60 Inch LBS as the torque spec. I ended up torquing all bolts to 100 Inch Pounds. Engine is running well, but I have some head bolts that are tapped to 1/4" and 5/8" because of the previously bad spec (over-torqued and stripped/broke). The remaining original bolts are metric, but are around
10-28 in American specs. That makes 3 different bolts sizes ! For 27 year old outboard that still runs well, I am very happy !
Thanks for the help !
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
15hp evinrude head torque specs Osprey Marine Johnson & Evinrude Outboards 4 January 6th, 2008 08:20 PM
Torque Specs Head jdtower23 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 July 13th, 2007 11:34 PM
Force 115HP head torque specs tazameir Force & Chrysler Outboards 4 April 25th, 2006 08:27 AM
head torque specs? Aquanut1 Johnson & Evinrude Outboards 1 August 17th, 2005 11:26 AM
Need Torque Specs for Head on 4 stroke '97 Merc 9.9 Shawzee Mercury & Mariner Outboards 0 November 11th, 2003 03:52 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
