  #1
Old September 2nd, 2008, 11:31 PM
skiff25 skiff25 is offline
Default 1996 25 HP Evinrude stalling, has no power
I have a 1996 25 HP Evinrude that idles smooth in or out of gear but when I put it in gear and give it any throttle it stalls out. It was in storage for about 2 years with fuel stabilizer in the fuel. When I brought it out of storage it would not fire at all. A friend of mine told me to saturate the carb with WD 40. I sprayed it in the throat and every hole I could find till it ran out the throat. After letting it set overnight I put new fuel and oil TCW3 50/1 in a new tank with a new OMC hose and bulb, pumped it up, turned the water on, hit the key and it was running. I had to keep it choked to keep it running for about 30 seconds, after that it ran smooth. While running on the flush plate it will rev up with the cold start and also in gear but when it is in the lake under pressure it will not rev at all, maybe 1500-2000 RPM. Thanks for any suggestions - Mark
  #2
Old September 3rd, 2008, 12:51 AM
R.Johnson R.Johnson is offline
Default Re: 1996 25 HP Evinrude stalling, has no power
Sounds like you probably have a varnished up high speed jet, take the carb apart, and clean it. Put it back together with a new kit.
  #3
Old September 9th, 2008, 09:38 PM
Thanks for the fast reply R. Johnson. That is what I'm going to try first. I will let you know how it turns out.
  #4
Old May 11th, 2009, 04:57 PM
Gdc Gdc is offline
Been there as well with 1989 25 hp evinrude. Haven't tore into the carb yet, what was the outcome of you're endeavour?
GDC.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1998 25 hp o.b. johnson stalling out ktlachance Johnson & Evinrude Outboards 4 July 16th, 2009 11:16 AM
'71 Evinrude 25 HP loses power at WOT STeveZ Johnson & Evinrude Outboards 7 January 13th, 2009 07:20 AM
95 evinrude 25 hp power serge at top speed imported_putz Johnson & Evinrude Outboards 1 July 21st, 2006 01:18 AM
1996 Mercury 150 Hp stalling captcharlie Mercury & Mariner Outboards 1 August 31st, 2002 08:38 PM
25 hp evinrude starts idles and will go in gear then no power Ron 101 Johnson & Evinrude Outboards 7 May 5th, 2002 06:08 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
