Driving me nuts !! I run high test gas with synthetic oil 50 : 1 mix> Engine completely dies when you lower throttle below 3/4 position. tried the jet adjusting new line cleaned carb thouroughly twice. Even switched to an electronic ignition module, still no better. I had it run smoothly once and once only ?? I do notice the coil housing or cover has a crack from age or heat or??? but I didn't think this would be the problem seeing that at full throttle the engine runs flawlessly. I know everyone want's to say low speed adjustment but believe me I've tried that a hundred times. It just completely dies very suddenly when you throttle back??? I even drilled two of the four exaust holes bigger in hopes of allowing the engine to breath a little better.
