Have a 140HP Johnson that for whatever reason will not go anywhere (above 2400RPM). Here is a video of the motor revving underload if it helps?
http://www.youtube.com/watch?v=n_LCy8wBs9I
Starts instantly and idles like a brand new motor.....
Here are the steps I have taken so far:
1) Replaced fuel tank.
2) Replaced fuel hose to tank.
3) Replaced fuel filter on pump.
4) Replaced every internal fuel line.
5) Rebuilt carbs completely.
Tests/troubleshooting:
1) Passes 7/16" gap spark test with nice blue spark on all holes.
2) Passes compression test 130-115
3) Passes pumping primer bulb with throttle applied (no change in performance)
4) Carb butterflies FULLY open at WOT, verified.
I am at wits end with this motor. I really need help. The lever on the control box that advances the timing does allow the motor to rev really high (above 2400 RPM CAP, in neutral). Prior to rebuilding the carbs, and fuel filter, the motor would only hit 1900RPM. On the low end, it seems great. Once you get to 40% and up it sounds as if the motor is falling flat on its face. Is there a timing advance that should be automatically going as it throttles up, because it almost seems like that might be the problem. It sounds great down low, but gets held back with 40% or more throttle.
My offer stands, if you tell me the problem and the proper steps to verify its the problem (ie, step by step troubleshoot). I will paypal you $10 the day my motor goes true WOT...lol
Here is a link to my original thread:
http://forums.iboats.com/showthread.php?t=266497
