Re: 95 Force 40 HP powerhead removal
I took the power head off my 99 40hp last year. Just from memory - The power head is attached to an adapter plate. You remove both together and unbolt the adapter plate after removal if necessary. You remove the lower cowl and the Power Head Adapter Plate assembly is held onto the motor by 4 stainless steel bolts from beneath. If you look inside the top of the motor you can see the top of the bolts just sticking up even with the adapter plate.
