I have a 1976 70 Horse. The over temp horn has not gone off and I have always ran more than enough 2 cycle oil in the tank. I find the math is easier at 3 oz per gallon. I removed the head and found that the top piston is burnt and the middle looks like it is starting. I put the head back on and ran a compression check and was amazed to see all three pistons were around 110lbs. The water pump is the original from 1976 as far as I can tell.
Would you guys recomend replacing the water pump impeller? Is there a test I can do before I do it? Also, should I do anything about the burt pistons. A new power head or rebuild is out of the question. One more question do you think a failing water pump or not enough oil in the fuel burt the piston.
Any help would be greatly appreaciated.
