Quote:
Originally Posted by BruceAML
The first thing you need to do is give us the complete model number from the data plate. Tell us what spark plugs you are using and the gap and torque of the spark plugs. Were the carburetors ever rebuilt and do you have the owner's manual? What position is the choke in when you start?
- Model Number: C115TXRT
- Spark Plug: NGK B8HS10
- Plug Gap: 0.039
- Hand tightened until spark plug is properly seated
- Carburetors have never been rebuilt
- I can not find the owners manual
- I normally use the manual choke and in cold weather I set the c
oke on full and in warm weather I set it on anywhere from full to 1/2 to 3/4.
Bruce,
While surfing the net and finding you, I also came accross a man with a Evenrude Ficht 115 that had the exact problem I did and this guuy who calls himself The Marine Doctor suggested that his problem could be the temp sensor. He stated that the temp sensor delivers the temp to the ECM...the ECM then uses that data and combines it with the other data it obtains from other sensors...checks a plotting graph...then supplies the correct amount of fuel.
This is all greek to me! I'm a cabinet builder and woodworker, mechanic work is far from my feild of expertise. What do you think about this?
One last thing, when I say cold start I mean after the engine has sat for a week or two no matter how cold or warm the temp is out side.
