I have an 1975 85 HP Mercury Outboard Thunderbolt Ignition. When starting the boat, I fully open up the warm up lever. The boat turns over and only idles between 800 - 1000rpm (roughly). I removed the hood and noticed that the distributor wasn't roating all the way. I pulled it (choke lever) and she went like crazy (approx 2500 rpm). However when I lowered the lever, it droped down to around 1000rpm and was running very rough again. I changed the plugs, wires and gas. I also tried adjusting the screw and it kind of helped for the ideling. However when I went to open it up again, (the lever) it's not engaging/pulling all the way. Only goes up a couple of hundred rpm and I have to manually pull on the choke lever to get it going. Any suggestions of how to fix this problem.
