Re: Evinrude VRO stalling and beeping
Welcome to iboats.
To start, post the model number so that we can determine a year for you.
Secondly, the beeping every other second is either a VRO failure, air leak in oil line, oil restriction...
the motor thinks that oil is not being supplied to the engine for one reason or another.
How did you convert to premix? Will pumping the fuel primer bulb pick it back up again? Are you using the VRO pump?
__________________
Chris
