  #1
Old September 1st, 2008, 10:30 PM
jgaryc3 jgaryc3 is offline
Question Mercury 150 Dual Cable Steering - AGAIN!!!! lol
Hello again. Have been working on the boat little by little.
I have installed my dual cable steering system and wow. Very hard getting under that console installing the racks. Routing the cable was the easy part, haha.
Anyways -
My new issue is this:
Cables are ran and racks installed. When I turn the wheel, both cables move as supposed to. The wheel doesnt turn smooth though. Its almost as it "clicks" when you turn the wheel. Its not really hard to turn, like I said it just sort of "clicks" when you turn it.
Has anyone ever experienced this before? Does anyone know why it would click click click instead of turn smooth? It doesnt really make a clikcing noise, just kinda click, clicks.
Thanks for any help!
  #2
Old September 1st, 2008, 10:40 PM
achris's Avatar
achris achris is offline
Send a message via Skype™ to achris
Default Re: Mercury 150 Dual Cable Steering - AGAIN!!!! lol
Sounds like to cables are too tight against each other.... Can you adjust the load of each cable against the other?
Chris.........
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
  #3
Old September 1st, 2008, 10:59 PM
too tight against each other? im not sure I know what you mean.
what do you mean adjust the load of each cable? how do I do that??
  #4
Old September 1st, 2008, 11:02 PM
achris's Avatar
The idea behind dual cables is that they load against each other to remove the 'sloppiness' found in a single cable. There should be a way of setting the load of each cable against the other.... Probably at the engine end, where the outer locking nut screws onto the steering tube. Or even an adjustment of the position of one of the steering tubes.
Chris........
__________________
  #5
Old September 1st, 2008, 11:20 PM
Quote:
Chris........
Well Im not really sure. I will check tomorrow though. If I cant find it I am taking it to have the motor serviced anyways so I may get them to check it out.
I just installed the system and dont have the rods through the tubes at the motor end yet. Is it just like that because I havent connected it to the motor yet?
  #6
Old September 1st, 2008, 11:35 PM
achris's Avatar
Why don't people give us all the information in the first post, instead of us having to extract it like teeth!!!
First post...
Quote:
Originally Posted by jgaryc3 View Post
...I have installed my dual cable steering system and wow....
Last post....
...I just installed the system and dont have the rods through the tubes at the motor end yet....
Tell us everything in the first post and we can stop all this time wasting!!!
__________________
  #7
Old September 1st, 2008, 11:43 PM
lol sorry. well do you think thats why its doing that? will it be smooth once the rods are in the tubes?
  #8
Old September 2nd, 2008, 11:45 AM
j_martin j_martin is offline
Like Achris said, don't start a new topic every time you come back. It breaks the thought train for folks trying to help.
You shouldn't have any clicking. It sounds like you don't have the rack seated tightly on the helm. It should turn smooth as butter with one finger.
They go in pretty tight at the console, but you mustn't kink them. There are 2 minimum radius bend specifications. A tight one at the helm end, and a wider one everywhere else. Be sure you stay within that spec.\
It is possible that there is something wrong with the NFB mechanism in the helm.
If it turns pretty easily, you may be feeling the NFB system ratchetting with your safe-cracker fingers. When you get the cables installed and properly pre-loaded, it should go away, and the steering will be slightly stiffer.
hope it helps
John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Steering Cable for Mercury 150 Black Max jgaryc3 Mercury & Mariner Outboards 19 August 20th, 2008 12:44 PM
Detmar dual steering cable blues Rev. Boat Topics and Questions (not engine topics) 1 August 13th, 2007 07:55 AM
Replacing dual cable steering setup peaser Boat Topics and Questions (not engine topics) 1 January 4th, 2007 11:58 AM
Dual Steering Cable Replacement fxdl Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 August 31st, 2005 01:22 AM
Cable steering with dual helms CaptMick Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 9 October 23rd, 2003 03:07 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
