imported_Jimbo
- Jul 15, 2006
- 43
So my bad luck with this engine continues. After about 25 hours of operation with the boat since I bought it the engine begun to make a lot of noise, I immediately shut it down and paddled to the nearest ramp (which luckily was only 15 min of paddling away). When spinning the prop i could feel that someting was wrong with the gearcase so I dropped it and took it apart. The inside was a complete mess, the forward gear and the gear on the shaft was completely worn down on some tooths (my guess is that a tooth broke of and chewed away on the gears).
So my options now are to try to find a used gearcase or rebuilding the one I have. I have a few things which i need expert advice on before considering to rebuild:
Question 1: The hole in the lower unit where the vertical shaft is rotating have been scratched by the metal parts which was pumped up together with the oil by the shaft (the shaft itself does not seem to be damaged). Also in the area where the top bearing on the shaft is located there are rotation-marks in the cast-aluminum. Would it be alright to hone these areas, or does this mean that the gearcase itself is destroyed? Will attach photos as soon as I get back from the cabin...
Question 2: How hard is it to get the shimming correct? I don?t want to spend money on rebuilding it myself if I screw up with getting the tolerances correct...
Question 3: Do you think I?m getting on over my head with doing this myself, I (of course) have the Clymer manual, and will follow the instructions carefully if I decide to do the work myself. I am rather experienced with working on motorcycles, but have not really done any advanced things on outboards.
Thanks!
//Jimbo
Thanks!
//Jimbo
