  #1
Old September 1st, 2008, 08:37 PM
sparky134 sparky134 is offline
Default evinrude cooling question 1962 40 hp
I am new to boating and have a cooling question about my 1962 40 hp. At low speed I have water flow through the engine but above 1/2 throttle no water comes outthe piss hole. When the motor is taken back down to a speed where the water is coming out the water is hot but not scalding and drops in temp in a few minutes. The water pump was serviced by a evinrude repair shop this year. Boat runs fine, just worried.
  #2
Old September 1st, 2008, 09:40 PM
tx1961whaler tx1961whaler is offline
Default Re: evinrude cooling question 1962 40 hp
These motors do not have a reliable tell-tale out of that exhaust port. When you're at low speed there is plenty of backpressure on the exhaust, and the water can shoot out of the hole. When you're up on plane, you lose the back pressure because the exhaust is sucked out due to the forward motion of the boat. About the only way to really tell is to take the cover off, run it for a bit, and put your hand on the head (probably shut it off first). If you can hold it there for a count of 3, then it's probably OK. If it burns the s**t out of you something's wrong
Another way is, if after running it, and you come back to slow/idle speed, NO steam should ever come out of the exhaust port. Hot water, yes, steam, no!
Also, keep your fingers and sleeves out of the flywheel
  #3
Old September 2nd, 2008, 08:34 AM
Thanks, that helps alot! Jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1962 Johnson 40 hp Parts. robandbob Johnson & Evinrude Outboards 2 June 9th, 2007 08:39 AM
1962 40 hp evinrude reeds jmc03021013 Johnson & Evinrude Outboards 5 April 24th, 2005 02:14 PM
1962 40 HP Seahorse moganman Johnson & Evinrude Outboards 6 December 13th, 2003 07:49 AM
1962 40 HP Seahorse moganman Johnson & Evinrude Outboards 2 December 12th, 2003 05:36 AM
1962 40 hp johnson--flywheel bear_01 Johnson & Evinrude Outboards 7 December 16th, 2002 06:22 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
