BIGFISHING
- Jun 23, 2008
- 24
hi i have a 72 merc 40hp 2 cyl, my problem is this if i adjust the low speed needle to get the eng to idle and go into gear smoothly and stay running it
looses its top end power no good over half throttle. if i back the low speed
needle out it will not idle unless i move the idle lever way up and then have
to be play with the idle lever while putting in gear but it will run much better
at top end. i have had the carb off and it did have a clogged orifice. Does it have a high speed adjustment i do not see one. Also when the needle is backed out for top end power it starts to leak fuel. any idea will help THANKS
