Hello, i know nothing about outboard motors. I have a 1978 evinrude 75 hp 3 cyl and when i put it from neutral to forward it will want to bog down and die. The only way i can really get it to go at times is to basically neutral drop it. Use the warm up lever and rev it high then slam it into gear. Obviously this is a bad thing to do. I checked all of the cylinders doing a drop test and when i pulled the plug off the top one it seemed to run better. they all spark. Also i noticed that if i choke the motor while it is running that gas will pour out of the carbs and down the plastic piece of the air cleaner. what does this mean? any help is appreciated.
