BLige pump
Tony F
I noticed that when i put the pump on it blows the circuit. I reset the circuit
breaker and turn the pump on it blows the circuit again. Any suggestios
hazwild
Re: BLige pump
unhook the pump then hit the switch if it does not blow then you have a shorted pump
marine4003
Re: BLige pump
wires are shorting out...check the red/black wires from the pump to the switch..somewhere along the line there immersed in water or touching..said and done,its not often the pump motor shorts,just the wires.
tashasdaddy
Re: BLige pump
they do burn up. especially in salt water environment.
